• 05.10.2026, 10:22
Asryan
Ek aio pump plugged on quadro ?
Saturday, January 2nd 2021, 7:22pm
I have a ek aio, I plugged the pump on the aio pump header but i was wondering if plugging it on my aquasuite quadro fan controller could damage it? I just got a replacement unit because last one was getting loud and I was wondering if it could be linked to it somehow.
At 100% it's not loud but I'm very noise sensitive and I can still hear it
https://youtu.be/rwf5qB7_lhA
The one I had before was a lot louder
Also could it damage it to set a speed curve for the pump or is it better to leave it at 100% or at a fixed value like 75 all tje time?
Before i had it at 35% until 50c and then 100% at 65 for instance
Thank
This post has been edited 1 times, last edit by "Asryan" (Jan 2nd 2021, 10:46pm)
Kuminauha
Saturday, January 2nd 2021, 11:04pm
Its no different than plugging it into motherboard PWM header.
Hufeisen
Saturday, January 2nd 2021, 11:37pm
Depends on how much Power the Pump needs.
The Quadro can supply up to 2A on each Fan connector, and the Quadro has Overcurrent Protection.
If the Pump need too much power, the Quadro will turn off the Pump.
Asryan
Sunday, January 3rd 2021, 9:29am
Well it was working fine but I was wondering if it could cause issues ir using a custom speed curve
Psychor
RE: Ek aio pump plugged on quadro ?
Saturday, January 16th 2021, 1:54am
Thank
I do this, but I don't adjust the power. I'm curious what AC says about adjusting the pump power.
