• 01.10.2026, 11:28
swashington87
Trying to understand how the Octo controller Works
Sunday, January 3rd 2021, 7:53pm
For Fan Control I'm assuming that, as long as I use a 3 prong splitter, I can control all 19 of my fans using the following system. Can someone verify this.
Fan Control
  • Aqua Octo Fan Controller
    • Channel 1
      • Fan Group 1 - Top Radiator Pusher
        • Fan 1 - Noctua NF-A12x15
        • Fan 2 - Noctua NF-A12x15
        • Fan 3 - Noctua NF-A12x15
    • Channel 2
      • Fan Group 2 - Top Radiator Puller
        • Fan 4 - Corsair QL 120
        • Fan 5 - Corsair QL 120
        • Fan 6 - Corsair QL 120
    • Channel 3
      • Fan Group 3 - Bottom Radiator Pushers
        • Fan 7 - Arctic P12 PWM
        • Fan 8 - Arctic P12 PWM
        • Fan 9 - Arctic P12 PWM
    • Channel 4
      • Fan Group 4 - Bottom Radiator Pullers
        • Fan 10 - Corsair QL 120
        • Fan 11 - Corsair QL 120
        • Fan 12 - Corsair QL 120
    • Channel 5
      • Fan Group 5 - Side Radiator Pushers
        • Fan 13 - Corsair QL 120
        • Fan 14 - Corsair QL 120
        • Fan 15 - Noctua NF-A12x15
    • Channel 6
      • Fan Group 6 - Side Radiator Pullers
        • Fan 16 - Arctic P12 PWM
        • Fan 17 - Arctic P12 PWM
        • Fan 18 - Arctic P12 PWM
    • Channel 7
      • Fan Group 7 - Rear Exhaust
        • Fan 19 - Corsair QL 120
    • Channel 8
      • Not In Use
For LED control, I am confused on what exactly the Splitty4 does. Does it "Clone" its output to all LED devices connected to the system? Would 2x QL120 plugged into a Splitty4, then plugged into an LED channel on a Aqua Octo would show-up as 34 LEDs connected to the system (both fans would produce cloned output) or would it show as 68 LEDs in total?
Also, does everything connected to a single Splitty4 need to be the same make and model?
LED Control
  • Aqua Octo Controller
    • Channel 1
      • RGBpx Splitty4 #1
        • 30 LED - Lian Li O11 Dynamic XL
        • 28 LED - Phanteks NEON Digital-RGB LED Strip #1
        • 28 LED - Phanteks NEON Digital-RGB LED Strip #2
    • Channel 2
      • RGBpx Splitty4 #2
        • 28 LED - Phanteks NEON Digital-RGB LED Strip #3
        • 28 LED - Phanteks NEON Digital-RGB LED Strip #4
        • 28 LED - Phanteks NEON Digital-RGB LED Strip #5
  • Farbwerk 360
    • Channel 1
      • RGBpx Splitty4 #3
        • 34 LED - Fan 4 - Corsair QL 120
        • 34 LED - Fan 5 - Corsair QL 120
    • Channel 2
      • RGBpx Splitty4 #4
        • 34 LED - Fan 6 - Corsair QL 120
        • 34 LED - Fan 10 - Corsair QL 120
    • Channel 3
      • RGBpx Splitty4 #5
        • 34 LED - Fan 11 - Corsair QL 120
        • 34 LED - Fan 12 - Corsair QL 120
    • Channel 4
      • RGBpx Splitty4 #6
        • 34 LED - Fan 13 - Corsair QL 120
        • 34 LED - Fan 14 - Corsair QL 120
  • D5 NEXT
    • Channel 1
      • N/A
Hufeisen
Sunday, January 3rd 2021, 10:20pm
No. the Splitty4 is daisy chaining the connectors. It will only work when there is a Data Out cable on the Connector.
It will show up as 68 LEDs, and each one can be addressed.
The Phanteks LED strips do not require a Splitty4. You can plug it directly into the RGBpx Port using an Adapter ( https://shop.aquacomputer.de/product_inf…roducts_id=3829 ) and a rgbpx cable ( https://shop.aquacomputer.de/product_inf…roducts_id=3762 ) Then plug the second LED Strip into the end of the first LED Strip.
This post has been edited 1 times, last edit by "Hufeisen" (Jan 3rd 2021, 10:32pm)
Kuminauha
Sunday, January 3rd 2021, 10:37pm
Yes. I'm running Quadro with 3x ML120 fans on each channel.
