• 30.11.2026, 22:31
cptninc
Feature Request: Update all device firmware at once
Monday, January 11th 2021, 5:46pm
Currently, a reboot of Aquasuite is required for each device that needs a firmware update. My setup has 3 D5 Next pumps, 3 highflow NEXT sensors, an aquaero6, a Vision NEXT block, a Quadro, and a Farbwerk360. This currently requires 10 Aquasuite reboots any time firmware needs to be updated.
It would be great if this process could be simplified. The easiest way would be to give me the option to reboot Aquasuite later instead of the current arrangement which forcibly reboots Aquasuite each time. A less easy way would be to implement a feature which updates all firmware at once. I'd be happy with just the first one.
Monday, January 11th 2021, 5:53pm
You can reboot your system when all updates finished. You have to restart the aquasuite after each update.
cptninc
Monday, January 11th 2021, 7:30pm
Yes, that is correct. I would like to not have to restart the Aquasuite application 10 times every time there is an update. The 10 application restarts turn a 2-minute process into a 20 minute process.
