• 14.11.2026, 00:05
Lucky75
Reduce Water Pump RPMs
Saturday, January 16th 2021, 11:17pm
Hello Guys,
I have a question about aquastream ULTIMATE pump.
When I use aquasuite and configure pump for curve settings pump's rpms cannot go under 3000 rpm.
It is possible to put that pump on 2000 or 2400 rpm ? And how ? :huh:
JustinThyme
Sunday, January 17th 2021, 6:52am
Its about the limitation that pump. Any lower and they may stall, All depends on the individual pumps and their PWM controllers, this one is strictly voltage. Some will go a little lower than others but 3000 is the minimum on the spec sheet for that pump. If you were to put it on a variac and dump the voltage too low it will vibrate clean out of your case and onto the patio right before it just plain stalls.
Similar threads
