• 10.10.2026, 19:00
Syndra
Airplex GIGANT 3360 inlet and outlet port
Monday, January 18th 2021, 6:04am
Does anyone know which port on the bottom backside of the radiator is the inlet and outlet or does it not matter?
Monday, January 18th 2021, 12:13pm
Hope THIS helps
Syndra
Monday, January 18th 2021, 7:06pm
Thank you InfoSeeker. That is what I needed. I had the inlet and outlet backwards, but I was only rinsing the radiator at most for several cycles that lasted only a few seconds. That thread will also help with mounting the pump and reservoir inside the radiator, which was going to be my next question.
This post has been edited 1 times, last edit by "Syndra" (Jan 18th 2021, 7:07pm)
Monday, January 18th 2021, 7:54pm
I went the route I did in order to have dual pumps.
If you only use a single pump in the gigant, it may be best to use the aquacomputer solution.
With their solution you should be able to mount a few fans inside the bottom half/.
