• 30.09.2026, 01:01
DirtyBear
D5 Next Noise
Monday, January 18th 2021, 11:59pm
Got no Idea why the D5 Next sudden have a high pitch Noise !! Its driving me MAD lol :cursing: ??? it used to be very quiet
Please Help !
PS : and it sounds like Wooooooooooooooooooooooooo ! not Veeeeeeeeeeeeeeeeeeeeeeeeeeeeee ! :whistling:
This post has been edited 1 times, last edit by "DirtyBear" (Jan 19th 2021, 2:23am)
DirtyBear
Tuesday, January 19th 2021, 9:10am
looks like no one knows why the D5 Next suddenly got this high pitch Wooooooooooooooooo sound :wacko:
Tuesday, January 19th 2021, 3:08pm
Could it be because of the very daring question?
Would you also ask a car mechanic, my car clacks "clack, clack, clack" what is that?
Here all information is missing, which would perhaps make a solution possible, or also only a thought beginning would give.
Without information about the pump top, changes in the noise at different speeds, the coolant used, etc., it is not possible to find a solution.
Translated with www.DeepL.com/Translator (free version)
Tasky
Wednesday, January 20th 2021, 11:00am
Micro bubbles trapped around the bearing?
Possibly some grit stuck in there?
k2viper
Wednesday, January 20th 2021, 3:30pm
If you look at D5 impeller you can see a thin opening in the center, so trapped bubbles will leave the bearing when the pump is off. Meaning pump has been oriented up top or side, or in its recommended orientations.
If so, trapped air bubbles are unlikely to be the case.
DirtyBear
Thursday, January 21st 2021, 1:50am
I know u all wants to help ! but none of u read my question !
" I said the high pitch sound came suddenly ! and used to be very quiet "
PS : I got the D5 Next since they came out , that means I been using them for years ! don't think bubbles will trap in there for years
This post has been edited 2 times, last edit by "DirtyBear" (Jan 21st 2021, 1:54am)
DirtyBear
Thursday, January 21st 2021, 1:52am
And I think Taubenhaucher
you need to change your car mechanic because your car used to go
Roooomm roooom suddenly went clack clack and he don't know what happened 8|
Thursday, January 21st 2021, 8:46am
Then go for the simplest and safest solution, remove the pump, the D5 has only one moving part and that is the impeller, which is mounted on a ceramic ball.
Clean the impeller, the ceramic ball and the pump body.
If you find any deposits, they may be responsible for the noise.
Kuminauha
Thursday, January 21st 2021, 11:22am
Some deposits may have caused the pump impeller to be out of balance, so as mentioned above, dismantle the pump and clean everything.
Here's jays two cents cleaning D5 pumps
https://www.youtube.com/watch?v=vRGS4GJ-NQU
This post has been edited 1 times, last edit by "Kuminauha" (Jan 21st 2021, 11:24am)
