• 13.10.2026, 16:09
f1fan07
Splitty4 aRGB strips acting in parallel rather than series
Thursday, January 28th 2021, 3:17am
I feel like I am going nuts..
Issue, aRGB strips acting in parallel rather than series, both hooked up with adapters to corsair headers. Tested on both versions of the Splitty4.
No matter how I define RGB controllers in Aquasuite, the settings just mimic across both. I just feel like I'm missing a config or something. Any help would be appreciated.
I have a similar setup in a system with 3x corsair ML120 rgb fans and an argb strip built into the Lian Li PC-O11XL with corsair 4 pin adapter and everything behaves as expected. I have the 3 fans set up as one block of 12 leds and the strip as another block of 28 leds. I can control them as I see fit.
Setup:
D5 NEXT with aquabus connector and rgbpx connector into splitty4
Aquacomputer 53270 RGBpx 30 aRGB strip plugged into aquacomputer RGBpx cable to aquacomputer adapter 53285 to corsair 4-pin adapter
Heatkiller size M addressable RGB strip with adapter to corsair 4-pin
Specifications:
Voltage: 5V
Connector: 3-Pin (5VDG, 5V)
LED: 21x SMD RGB
This post has been edited 5 times, last edit by "f1fan07" (Jan 30th 2021, 11:22pm)
Hufeisen
Friday, January 29th 2021, 3:54pm
Can you upload a picture of the connections?
Your setup is hard to understand with so many adapters.
And post a link to the corsair 4-pin adapter you are using.
This post has been edited 1 times, last edit by "Hufeisen" (Jan 29th 2021, 4:04pm)
cptninc
Friday, January 29th 2021, 6:42pm
Try running the strips connected to each other in series using the built in connectors. I believe those are intended to be used with their built in passthrough rather than the arrangement in the Splitty4.
Similar threads
