• 30.09.2026, 03:21
LuttyMiix
[SOLVED] Farbwerk 360 Over Current
Thursday, February 11th 2021, 9:17am
Hello all !here is my problem : Got an OCTO + Farbwerk 360 + Splitty4 i my setup,
My Farbwerk setup :Connector 1 : 4 Fans argb 13 leds on a splitter 52 leds
Connector 2 : 3 Fans argb 13 leds on a splitter 39 leds
Connector 3 : 3 Fans argb 13 leds on a splitter 39 leds + case argb strip + power button argb
Connector 4 : 2 waterblocks barrow (CPU+GPU) on a Splitter so nearly 20-25 leds
With this setup, when i try to turn all white, i got the over current message and the controler wait next start to restart.
Is that normal or not. I've read that normally Farbwerk 360 handles 4*90 leds
Thanks all ! 8)
This post has been edited 2 times, last edit by "LuttyMiix" (Feb 11th 2021, 10:49am)
Thursday, February 11th 2021, 9:36am
Fill the invisible area with a white color. (for every strip)
LuttyMiix
Thursday, February 11th 2021, 9:52am
What do you call "invisible area" ?
I have set on my Aquasuite 13 leds per channel since it's all parallel and not in serial.
I tested with just 4+3 fan other are deactivated and message pops, no more leds display.
k2viper
Thursday, February 11th 2021, 9:59am
In aquasuite, fill the unused length of the 90-leds available strips with all-white LED controller.
LuttyMiix
Thursday, February 11th 2021, 10:08am
Oh ! Ok, i will try this ! Thanks for the advice, will give my feedback when i tested this !
LuttyMiix
Thursday, February 11th 2021, 10:48am
After test, problem solved ! Thanks for this trick !
