• 21.11.2026, 13:04
drdbkarron@gmail.com
Repair Delrin plastic G 1/4 port threads in radiator
Friday, February 19th 2021, 3:33am
A radiator fell off the bench during an overhaul, and the fitting in one of the fluid ports became 'cocked' or cross threaded or not right.
I dissembled the fitting from the Delrin body and looked at the threads. There was some damage.
Some of the ridges of the threads were missing.
I was able to screw it back in carefully, so as not to get it cross threaded.
I don't know if it will leak yet.
I am considering thread locking compounds (Locktite blue?)
I have repaired M4 threads in the soft plastic with thread inserts.
Where can i get a thread repair kit for the larger G1/4 fittings?
Is such tooling and thread inserts made?
Friday, February 19th 2021, 5:11am
Aqua Computer once recommended UHU Endfest Epoxy for repair of a aquastream's port
After the repair, you should use silicone thread seal instead of the O-ring.
I don't take responsibility at all!
Friday, February 19th 2021, 11:03am
I had a similar issue having cross threaded a fitting into a GIGANT's port.
I re-tapped the cross threaded port using a G3/8 bottoming camfer tap for plastic.
Then I used a G3/8 to IG1/4 adapter.
Also, all risk is yours.
Thursday, June 24th 2021, 1:58am
Thank you for your responses.
I will superglue a thermocouple bushing into the damaged port .
Thank you for all your thoughts.
