• 01.11.2026, 13:11
Marucins
Update rig - new aquacomputer components (D5 NEXT and AMBIENTpx)
Wednesday, February 24th 2021, 3:54pm
Hello
What I intend to do:
1. Replace the pump D5 Pump Motor with USB and Aquabus Interface (41093).
2. Add a phenomenal AMBIENTpx effect to the monitor (AG353UCG).
https://youtu.be/XNnAkMD9L1I?t=11
I have Aquaero 6 PRO. I care about maintaining full control over devices and lighting (Aquaero / Aquasuite X)
Ad 1.
I'll buy it ULTITUBE D5 200 PRO reservoir with D5 NEXT pump
https://shop.aquacomputer.de/product_inf…853&language=en
I want to connect it to Aquaero
Do I need an extra cable?
Something like that? https://shop.aquacomputer.de/product_inf…487&language=en
There is a cable in the box for connecting RGBpx LED ring - where to connect it?
The priority is control Aquaero/Aquabus and I see that there is one input that works or as aquabus or as RGBpx LED.
Ad 2.
To create this effect as on the movie (AMBIENTpx). I need Farbwerk 360?
If so, does this set be appropriate?
farbwerk 360 -> https://shop.aquacomputer.de/product_inf…roducts_id=3798
RGBpx lighting set for monitors, 60 addressable LEDs -> https://shop.aquacomputer.de/product_inf…roducts_id=3771
RGBpx LED strip 32 cm, width 10 mm, 15 addressable LEDs -> https://shop.aquacomputer.de/product_inf…roducts_id=3767
RGBpx cable, length 4 cm or 10 cm -> https://shop.aquacomputer.de/product_inf…roducts_id=3762 or https://shop.aquacomputer.de/product_inf…roducts_id=3763
I can not connect the LED strip directly to the LED strip and needs a cable. What did I write a line above?
Ad 3.
What else do I have to buy, for D5 pump?
What else is still needed in addition to Farbwerk 360, LED strips, cables to connect the LED to LED?
I am asking for your help.
I want to buy everything at one time. He does not want to order missing elements. That's why I need to understand it all.
Hufeisen
Wednesday, February 24th 2021, 8:14pm
RGBpx requires an USB connection, it is not possible to control RGBpx with Aquabus.
This applies to all RGBpx devices.
This post has been edited 3 times, last edit by "Hufeisen" (Feb 24th 2021, 8:25pm)
Marucins
Thursday, February 25th 2021, 6:57am
https://youtu.be/ya-8E7Hzj3s?t=12
In this video there is one input which is either RGBpx or aquabus.
That's how I understand it.
If I connect RGBpx ring to the D5 pump, will I have full flow control when I connect the pump via USB to my computer?
Hmmm...
I wonder if each edge of the monitor AMBIENTpx should have a separate assigned address, and with it a separate farbwerk 360 cable?
Can I address more than 90 LEDs on one farbwerk 360 output?
New: aquasuite X
///edit
I have the answer for number of LEDs.
Technical details
- four channels for up to 90 LEDs each
This post has been edited 5 times, last edit by "Marucins" (Feb 25th 2021, 7:23am)
Hufeisen
Thursday, February 25th 2021, 7:12pm
Yes.
