• 07.10.2026, 02:00
unbendingcrab
Updating Firmware on Quadro
Friday, March 26th 2021, 11:18pm
Having trouble upgrading the firmware on my Quadro. Looks like it currently has version 1023, which Aquasuite X.38 says it needs to upgrade?
When I click on the update firmware button the blue striped progress bar appears but it sits at 0%, and all my fans stop running.
I've also tried doing the firmware upgrade with only USB and power connected to the Quadro, but it still just sits at 0%.
This is all in a fresh install of Windows 10 in a VirtualBox VM, since the host computer is running Linux, and there's no other software installed in the VM. I don't have a physical Windows 10 computer I could try this on, so hoping there's something else I could try?
Saturday, March 27th 2021, 6:35am
Try to change the USB Port and disconnect all other devices. do not use a usb hub during the update.. otherwise try the update from a different computer
unbendingcrab
Saturday, March 27th 2021, 8:09pm
Was able to borrow a friend's computer to do it, upgraded to 1027. Now I can program the Quadro from my VM, so all working as expected now. Thanks!
nleitao
Wednesday, April 7th 2021, 11:37am
I had exactly the same problem. Tried all but the "other computer option" I don't have other desktop I can use to update it, laptops won't have a usb header plug...
Wednesday, April 7th 2021, 12:30pm
Wednesday, April 7th 2021, 1:25pm
Something like THIS may also be useful for devices with a PicoBlade USB 2.0 port (e.g. quadro, octo, d5 next, flow next)
nleitao
Sunday, April 11th 2021, 3:54pm
I drove to the next city to my brother-in-law house, to update this firmware on his computer...
Exactly the same outcome...
I'm out of suggestions... It's not the USB cable. Windows device manager can identify and correctly install its drivers.
Is there a recovery mode or other options not suggested in the aquasuite?
This is so unfair...I didn't ask any update, now I can't use it anymore... frustation... :(
