• 22.11.2026, 22:50
foresight
D5 Next + High Flow next and aquaero 6 LT
Friday, April 23rd 2021, 3:48am
This might have been answered before, but I was unable to find any.
I have a D5 Next, High Flow next and aquaero 6 LT. I want to connect both pump and sensor to the aquaero, and then the aquaero to my motherboard.
I am a bit confused as to which extra cables I need. Any answer is much appreciated :)
Silky_
Friday, April 23rd 2021, 4:17am
As for the high flow next, it will require an Aquabus cable (4 pin to mini connector).
D5 next on the other hand “ Simultaneous connection of RGBpx products and aquaero 5/6 via aquabus is not possible”
Might be better off connecting those two through USB via a Hubby 7 (if you need more USB connectors)
Hope this helps!
RE: D5 Next + High Flow next and aquaero 6 LT
Friday, April 23rd 2021, 4:18am
Which Operating System are you installing?
Do you plan to run the aquasuite?
foresight
RE: RE: D5 Next + High Flow next and aquaero 6 LT
Friday, April 23rd 2021, 4:24am
It's going to be a windows gaming PC, and yes I was planning on using Aquasuite for monitoring
Friday, April 23rd 2021, 6:36am
If you work with Windows and the Aquasuite you don't need additional cables, a USB cable is included with all devices.
Just plug everything into the mainboard or an internal USB hub.
foresight
Friday, April 23rd 2021, 9:40pm
Thanks for the info gents, think I've got a functional plan now :)
