• 17.11.2026, 07:04
Gibo
Pressure leak
Monday, April 26th 2021, 11:12pm
Hello,
I just installed every part of the custom loop ( CPU block, GPU Block, 2 x HLabs GTX 420, D5 Next, High flow NEXT, Eisbecher 150) and after checking with Dr.Drop for leaks, I saw the pressure drop from 0.50 bar to 0.48 bar in around three hours...
Is that considered acceptable or I should have no leak at all ?
Thanks.
Bartdude
Tuesday, April 27th 2021, 6:51am
Can you physically see a leek? Probably more likely be due to air bleeding from the system
Gibo
Tuesday, April 27th 2021, 9:22am
Let me rephrase...the air drop of 0.02 was during the air pressure test with Dr. Drop...
No liquid in the custom loop.
Just testing with Dr. Drop.
Tuesday, April 27th 2021, 12:15pm
Does the loop continue to loose pressure, or does it settle in after time?
Gibo
Tuesday, April 27th 2021, 2:15pm
Apparently it settled.
This morning I added the coolant and later today I will check, but I believe its all good.
I left the PC off so the pump is not running.
Put some paper towel under pump, res and blocks...
We'll see. Hopefully is all good.
Similar threads
