• 18.11.2026, 00:50
xhamster
Aquaero solder rookie misktake
Wednesday, June 2nd 2021, 10:28am
I think I over heat the board and the ring comes off, Is there any way to fix it? Any tips will be appreciate.
Thanks. Pics attached
xhamster has attached the following file:
  • DSC_2044 1.jpg (444.07 kB - 260 times downloaded - Last download: Nov 16th 2026, 3:17pm)
Wednesday, June 2nd 2021, 10:36am
The 2 Pads in the middle are ground. This 2 pare are connected in the bottom pcb layer. I think you pcb is working, you have only connect the 2 Pins on the bottom layer.
xhamster
Wednesday, June 2nd 2021, 12:06pm
Unfortunately the back ring is off too. I tried to solder it directly on the board but it won’t boot the fans.
What is the ring called? I’m think buying some online to replace them order to see if it will help
Back pic attached.
Wednesday, June 2nd 2021, 1:06pm
this is the 12V supply, the pad is directly connected to a inner layer.
you can try to connect the 12V supply to the + connector from the capacitor next to power connector.
xhamster
Thursday, June 3rd 2021, 7:59am
Is this you're talking about?
  • DSC_2047.jpg (617.81 kB - 231 times downloaded - Last download: Nov 16th 2026, 12:06am)
Thursday, June 3rd 2021, 8:42pm
no, this is the Ground Terminal.
Similar threads
