• 07.10.2026, 07:19
Rocketlaketx
Testing: Operate Accessories Bypassing Motherboard
Saturday, June 19th 2021, 8:41am
What are my options, available to me, to operate installed water pump loop, case fans and addressable rgb without motherboard/pre processing system installation? I am familiar with procedure to jump start PSU; however, is there a controller/connection available to operate the accessories and water cooling loop bypassing main board?
Thanks
Saturday, June 19th 2021, 9:43am
For what purpose?
Basically the pump, fan controller and RGB need power from the PSU, so bridging the PSU is the only way to get power without needing the motherboard.
Another controller would also need power, so the problem remains the same.
Remayz
Saturday, June 19th 2021, 1:21pm
if you wonder about running the loop without software, well Aquasuite is very light, so it shouldn't affect system performace.
That said, you could setup fan, pump and RGB with aquasuite, and uninstall it completely. The controller will work the way you have set it up and won't need any input from the computer.
You'd need at least a temperature sensor on the water loop, connected to the controller to serve as control variable for your fans.
Rocketlaketx
Saturday, June 19th 2021, 10:13pm
Basically I wanted to run the testing, adjustments, loop setup,topping up loop, pressure testing, fan operations before firing up the computer system. Thank You
Tasky
Sunday, June 20th 2021, 3:53am
You can't really configure ARGB without the software to control it first. At best, you'll get the default pattern on power-up, which is usually Unicorn Puke.
Once configured, then it will run whatever you set it to do, provided that setup doesn't rely on motherboard-based data or sensors, of course.
The same will be true of many other software-based setups, like fan curves and the like - Once setup they'll run standalone just fine, but you need the mobo to set them up first.
Basic pump filling and loop stuff is done off a bridged PSU, as usual.
Rocketlaketx
Sunday, June 20th 2021, 5:51am
Thank you for all your valuable input.
Basically, I’m hearing that controllers & connectors are software oriented and can only operate connected to an active motherboard; that there are no controllers and/connectors that will operate connected only to a bridged PSU? Am I correct?
Has anyone heard about the fan kit LC-POWER Rheobus.
This post has been edited 2 times, last edit by "Rocketlaketx" (Jun 20th 2021, 6:12am)
biopunk
Sunday, June 20th 2021, 12:25pm
I'm using NA-FC1 controller for testing fans and pumps, it generates PWM signal when not connected to a motherboard.
Remayz
Sunday, June 20th 2021, 3:50pm
AC controllers work without motherboard. Aquasuite basically just program them, then they run autonomously.
The motherboard is only needed if you use software sensors to control the fans (components temperature readings, virtual sensors etc..).
If you only use like your water temperature sensor directly connected to a controller, it will run with only the PSU.
Rocketlaketx
Sunday, June 20th 2021, 8:16pm
AC controllers work without motherboard. Aquasuite basically just program them, then they run autonomously. The motherboard is only needed if you use software sensors to control the fans (components temperature readings, virtual sensors etc..).
I was not aware of A/C computer controllers, would you be so kind as to identify some of the well built and reliable A/C controllers available on the market?
I am not familiar with Aquasuite isn’t that a software?
Thank you.
This post has been edited 2 times, last edit by "Rocketlaketx" (Jun 20th 2021, 8:24pm)
Rocketlaketx
Sunday, June 20th 2021, 8:17pm
Thank you.
Remayz
Sunday, June 20th 2021, 9:55pm
Thank you.
I believe you had the answer in your other post in the german section.. AC = Aquacomputer. I was referring to Octo and Quadro mostly.. and yes they work with the Aquasuite software
This post has been edited 1 times, last edit by "Remayz" (Jun 20th 2021, 9:57pm)
Rocketlaketx
Sunday, June 20th 2021, 11:08pm
Thank you.
LOL My mistake, I misunderstood A/C to be alternating current, controllers operating via a wall A/C adapter instead of a computer PSU. OK, I see it now. Thanks.
Monday, June 21st 2021, 3:51am
The aquaero has a firmware virtual sensor that does not require the aquasuite if one wanted to fan control on coolant/ambient delta.
Remayz
Monday, June 21st 2021, 10:42am
ah good to know :) i only ever used the two i mentionned
