You are not logged in.
CodeZ1LLa
This post has been edited 2 times, last edit by "CodeZ1LLa" (Jun 26th 2021, 10:32pm)
CodeZ1LLa
This post has been edited 1 times, last edit by "CodeZ1LLa" (Jun 27th 2021, 6:13pm)
cptninc
This isn't entirely correct. The real answer is that there might be an error in the Nvidia driver but every developer other than Aquacomputer has implemented a workaround for several years ago.The GPU values are not displayed due to an error in the Nvidia driver see here
The data will not be available again until the driver is working cleanly.
CodeZ1LLa
No!but every developer other than Aquacomputer has implemented a workaround for several years ago
it is an NV bug. we can not fix this driver bug.
Quoted
The official word from AC is that they have no intention of fixing their own code
The NV driver has a issue and we have to support the broken driver when the driver interface use more and more memory.
Quoted
AC worked just fine and GPU wattage gone after AC update, not after nvidia drivers update
Only a few users think they need this sensor value. For all others this is a disadvantage if we implement the defective driver interface in our software.
Quoted
A lot of users have said that this is an important feature for them, so Aquacomputer is definitely aware of the problem
CodeZ1LLa
cptninc
I saw your post and used that to justify updating to 471.11 this morning. It's been only a few hours, but it appears that this does solve the problem. I'm still running X.38 and its memory footprint is still under 350MB after about 4 hours. The aquasuite service is showing a similarly reduced memory footprint.Multiple posts on HWINFO forum say that Nvidia driver ver 471.11 has fixed the memory leak problem. Red-Ray (author of SIV) is one of the people who posted there that it appears to be fixed. Red-Ray is not known for being wrong.
I hope that Aquacomputer will complete their verification of this and re-enable GPU wattage sensor data soon.
Thanks!
Thanks!
