• 23.11.2026, 02:02
Beun
Position fans on radiator
Sunday, January 16th 2005, 7:31pm
Does it matter if I fit the fans on top of the radiator, and thus suck the air through the radiotor. Or mount the fans under the radiatir and blow the air trough.
Most of the time I see the first solution. But I would rather use the last one, so my harddisk will fit better :)
Dragonclaw
Re: Position fans on radiator
Sunday, January 16th 2005, 7:50pm
just do what suits better, it does not matter ;)
but if you want to use one of the evos, you might need the docking modul, because the radiators have only mounting holes on one side!
Beun
Sunday, January 16th 2005, 7:57pm
Thanks I was hoping for that answer :) I use an airplex evo 240, and I mount it internally.
Puggy
Tuesday, January 18th 2005, 3:06am
Quoted from "Beun"
Same here. I have it on the top panel of my Lian Li PC7077 case with 2 fans pulling air in towards the rad. I the fans reversed, pulling air from inside the case out the top, but my temps were terrible. I'm going to use the mounting brackets on an EVO 120 in another case with 2 fans to cool an older P3 core Celeron.
