• 08.10.2026, 01:55
WinstonWoof
Display Aquasuite on Specific Monitor
Sunday, July 18th 2021, 6:11pm
Is it possible to set Aquasuite to display on a specific monitor ?
Had a good look but can't seem to find anything that will do it
Sunday, July 18th 2021, 8:23pm
Yes, but you don't assign a monitor.
Aquasuite considers all monitors as a single canvas. e.g. if you have 2 monitors side by side, both being 2000x1000 pixels, the canvas would be 4000 x 1000 pixels.
To place an object on the 'second' monitor, 10 pixels from the left edge, and10 pixels from the top you would specify the x/y as 2010/10. (settings.jpg)
If the monitors were one above the other, the canvas would be 2000x2000 pixels.
I am not sure how it works with 2 monitors side by side, with the right monitor designated as the primary (left monitor is #2), but you may need to use negative x in that case. Same if 2 monitors are vertically mounted and the 2nd monitor is the top monitor.
This post has been edited 1 times, last edit by "InfoSeeker" (Jul 18th 2021, 8:24pm)
WinstonWoof
Sunday, July 18th 2021, 11:07pm
To place an object on the 'second' monitor, 10 pixels from the left edge, and10 pixels from the top you would specify the x/y as 2010/10. ([attach]8525[/attach])
where the flip is that particular settings page?
DaLiu
Monday, July 19th 2021, 2:33am
It will be great if they will implemate an option to decide on which monitor you want to display the sensors.
Monday, July 19th 2021, 5:15am
  • select the overview page you want to work on
  • unlock the page to edit it
  • right-click on the object you want to move
  • select 'Settings' from the pop-up menu
Grestorn
Monday, July 19th 2021, 9:10pm
The way they did it might be a bit unintuitive, but it has the advantage that the display can span across multiple monitors.
WinstonWoof
Thursday, July 22nd 2021, 11:05pm
  • [attach]8526[/attach]
So you have to move each element individually ?
What a faff!!
Friday, July 23rd 2021, 1:20am
What a faff!!
It is possible to select any or all objects on a Overview page (select.jpg)
Then Drag & Drop to a new position (drag_drop.jpg)
But the resolution of your drop is limited to the steadiness of your hand, which may be improved by having the grid-lock turned on.
The optimum would be to select multiple objects and have the ability to offset all selected objects by a specific x/y, but that is currently not available.
Edit: link to a 10 SECOND CLIP showing a multi-object move.
This post has been edited 1 times, last edit by "InfoSeeker" (Jul 23rd 2021, 1:55am)
WinstonWoof
Friday, July 23rd 2021, 7:41am
What a faff!!
It is possible to select any or all objects on a Overview page ([attach]8560[/attach])
Then Drag & Drop to a new position ([attach]8561[/attach])
Which brings to mind 2 further improvements that could be made.
1) Enable CTRL+A to select All
2) Enable Scaling of window to better facilitate placing of widgets anywhere on the available canvas
WinstonWoof
Friday, July 23rd 2021, 7:47am
Of course I could always resize the AS window and stretch it over both monitors then drag & drop ;o)
Only PITA still then is lack of CTRL+A functionality
WinstonWoof has attached the following file:
  • Capture.JPG (443.23 kB - 206 times downloaded - Last download: Yesterday, 7:39pm)
WinstonWoof
Monday, July 26th 2021, 10:09pm
Damned annoying.
Since the update to X.41 I dont seem to be able to resize the Aquasuite window across multiple monitors :(
EDIT UPDATE
Closed & Reopened and worked as expected
This post has been edited 1 times, last edit by "WinstonWoof" (Jul 26th 2021, 10:16pm)
