• 29.09.2026, 06:10
Flop Ysh
D5 NEXT: Fan header not functionnal
Wednesday, July 21st 2021, 4:59pm
Hello!
it's me again ^^
that time I can't get the fan header of the d5 next working
changed cables, used only one fan... nothing. Did a factory reset too on the D5, didn't change anything
I first used the Splitty but when I plug the Splitty directly to the Mb that works as intended and with 4 fans on it.
What am I missing?
Hufeisen
Wednesday, July 21st 2021, 5:53pm
You have to configure the Fan Port in the Aquasuite Software..
You can select if you use it as FAN port or as FLOW port.
If Flow Port is selected, the Fans do not work.
Flop Ysh
Wednesday, July 21st 2021, 5:58pm
Thank you very much for your answer
I went through all the pages in D5 Next and Aquasuite sections, and I didn't find anything close to that ?( Could you guide me to where I can change that?
This post has been edited 1 times, last edit by "Flop Ysh" (Jul 21st 2021, 6:00pm)
Flop Ysh
Wednesday, July 21st 2021, 6:12pm
From the manual, it seems that the header is configured by default as a fan output. And if there is no virtual sensor using the header, the Fan panel under D5 NEXT is all I should need to set speeds and read the rpms...
I actually don't see what to do, since I did a factory reset and I don't have any virtual sensors
This post has been edited 1 times, last edit by "Flop Ysh" (Jul 21st 2021, 6:13pm)
Flop Ysh
Thursday, July 29th 2021, 8:12pm
tried again with the last Aquasuite software. Nothing changed. No surprise since the firmware hasn't been updated
I'm contacting the support
