• 08.10.2026, 01:23
turgin
D5 NEXT RGBpx output not working
Tuesday, July 27th 2021, 3:56am
I have a D5 NEXT that I've had connected via Aquabus for quite some time now. I'm reworking my loop and ditching the Aquaero and farbwerk 360 in favor of an Octo so I want to use the RGBpx output now. I have changed the D5 from Aquabus to RGBpx LED in the system tab and checked everything I can think of on the RGBpx tab as well. Lighting slider is on and there is a controller assigned but still no output at all. The pump LED ring works fine. I have tried a different cable, different strips and checked for bent pins all to no avail. I even tried a new install of Aquasuite and reset the pump to factory defaults.
Any other ideas or suggestions to get the RGBpx output to work?
Flop Ysh
Thursday, July 29th 2021, 7:57pm
Hi!
is that the same issue as [solved] D5 NEXT: RGBpx output not functionnal ?
This post has been edited 1 times, last edit by "Flop Ysh" (Jul 29th 2021, 7:58pm)
turgin
Thursday, July 29th 2021, 9:22pm
Hi!
I checked that setting first and also checked it via the pump display itself.
