• 11.10.2026, 14:17
d3smo
Fan speed goes to max speed even if output percentage is not
Monday, August 30th 2021, 5:46pm
I do have a strange issue with my Quadro since 3 days (my computer was of for 3 weeks due to holidays before). I control my top radiator fan speed using water temperature, usually and since i build my loop my fans run around 40-50% of their full speed (600rpm-700rpm), but strangely since 3 days, sometime and only for these fans the speed goes to full speed 1500rpm even if the control % stay at 40% or 50%. And it goes to normal behaviour some minutes after ? I do not change anything in my controls and i've update the latest version of aquasuite.
Karsten Ravneng
Saturday, September 4th 2021, 9:53pm
My OCTO is that way also, it just takes some time before it connects to the services. But if it is normal I don't know. It didn't do it the first week I had it.
d3smo
Monday, September 6th 2021, 8:22am
You can see below the illustration of the issue, my water temp is 32°, so the output current for the top fan should be 54%, it was the case but the fan run at full speed 1500rpm were it should run around 750rpm. After a few minutes it became normal, but sometime i've this strange behaviour !
Remayz
Monday, September 6th 2021, 9:15am
if you set it manually to that speed, or any other, does it respond well?
have you tried connecting them to port 3?
d3smo
Monday, September 6th 2021, 9:33am
No same issue, it does not change the speed of the fan only the output power.
No but i'll
d3smo
Friday, September 10th 2021, 9:34pm
I've connect top fans to port 2 of the Quadro and i do not have the issue anymore. I hope i'll not have the issue when i'm gonna us the port 3 in a couple of days when my 3800 will be under water and i 'll add 3 more fans connected to port 3 ...
