• 02.10.2026, 13:51
JBGamingPC
High Flow 2 sensor makes clicking/ticking noise
Tuesday, September 7th 2021, 2:01am
Hello,
I bought and installed the Aqua Computer High Flow 2 into my loop but it sounds like a ticking clock:
Video/Audio of the problem here:
https://www.reddit.com/r/watercooling/co…ng_noise_in_new
As you can see from the video, it is mounted flat to the bottom of the case, I have turned the whole PC sideways/back and forth a few to release any air but the issue persists. :S
Remayz
Tuesday, September 7th 2021, 9:50am
as they said in Reddit, i'd contact support to try to get it replaced.
The Flow2 can tick if installed vertically but as you have it here it should be totally silent.
Mine does that sound only when i tested it vertical.
In horizontal position, no matter the flow : zero sound.
Tuesday, September 7th 2021, 10:28am
At what flow rate does it tick?
It is known that ticking is normal from 150 l/h, as these are rates of flow that are rather unusual and unnecessary for water cooling.
Remayz
Tuesday, September 7th 2021, 11:56am
just FYI, i never heard any noise up to 300l/h ;)
the ticking seems to be slow so i suspect the pump isn't running very fast in the video.
JBGamingPC
Wednesday, September 8th 2021, 7:57pm
Thanks for the replys guys,
In terms of flow speed, I have 2x D5 pumps set to speed setting 3 out of 5. But I only have a cpu monoblock and 2 radiators on it using 16/10mm pipes. So its not like I have to set to max speed or anything, I did not try lowering the pump speed, but today I removed and send back the sensor to be replaced by another one.
Hopefully the next one will be without this problem but I will report back with updates on this.
