• 01.10.2026, 17:57
ngc
Water cooling on a moving/rotating platform
Tuesday, September 28th 2021, 4:51pm
Hi all,
Apologies if this is the wrong place to ask, but I have an unusual (or so I think) problem to solve.
I need to liquid cool a camera on that's on a moving platform (a large telescope), that will move in pretty much all orientations, upside down etc.
I am currently using something called an Oasis UC160 liquid chiller to cool the camera in the lab. It provides a steady temperature to camera and works very well in a stationary position. However, it will not function on this moving platform since the reservoir cannot operate in any other position than upright.
Does anybody know if an alternative reservoir exists which I could use in conjunction with my liquid chiller?
(the telescope is a bit too big to place the chiller/reservoir on the ground, tubing would get in a mess :wacko: )
Thanks!
This post has been edited 2 times, last edit by "ngc" (Sep 28th 2021, 4:57pm)
Tuesday, September 28th 2021, 5:06pm
Is it possible to use some kind of gimbal for the chiller and attach it to the telescope?
That would be the only thing that comes to mind.
ngc
Tuesday, September 28th 2021, 5:26pm
It's a tempting avenue to explore. I have had a google before, and found maybe the ZHIYUN Crane 3S as having the power/size to handle what I would need. But I have no idea how reliable or programmable such a gimbal would be.
Tempted to make one myself, but I don't think I have the time for that.
Tuesday, September 28th 2021, 6:57pm
You need a reservoir with an flexible membrane for compensation of expansion. The loop needs to be filled without any air using a vacuum pump to evacuate the reservoir and then fill it with fluid.
ngc
Wednesday, September 29th 2021, 12:59pm
That sounds like a good idea. I will investigate the options online. If you know of any good expansion tanks/vacuum pumps suitable for a system dealing with <0.5L of liquid please let me know.
Tasky
Thursday, September 30th 2021, 12:20am
The Leakshield can do that, right...?
Not sure if you'd need to connect it to a USB header for full functionality (if only just the onec for setup), but could be worth a look.
Similar threads
