• 12.11.2026, 17:32
chon
Dual Loop System and High Flow 2
Friday, October 8th 2021, 9:47pm
I am going to run a dual loop setup, where the CPU and GPU will have its own pump and reservoir. I currently have a Quadro and 1 x High Flow 2 sensor. I thought about picking up a second one, however, my Quadro only has 1 flow sensor input.
Is there any way to make this work, or another controller I can purchase from Aquacomputer?
Friday, October 8th 2021, 10:45pm
The aquaero 6 is the only controller with two flow inputs.
Two options available for the 2nd loop are:
  1. a second quadro/high flow 2 combination
  2. or a high flow next connected over USB
Remayz
Friday, October 8th 2021, 11:41pm
if it helps, the Farbwerk360 also has a flow sensor input, if you have more need for RGB channels
