• 06.10.2026, 19:14
knacker
Utlitube- in/out ports?
Tuesday, October 26th 2021, 5:46pm
can anyone confirm which port is in and which one is out as there are no markings on it that I can see- I assume that the left is out and right is in?
Thanks from a confused person :wacko:
Tuesday, October 26th 2021, 10:40pm
You may want to look a little closer around the ports. The MANUAL states:
Quoted
3.5. Integration into the cooling loop
Connect the return line to the reservoir connector engraved with the word “IN”
and connect the other line to the remaining connector. Use light force only when
screwing in fittings in order not to damage the threads in the plastic base part!
Edit: I believe you can see the 'IN' marking below the right port, looking at the ports (ultitube.jpg)
This post has been edited 1 times, last edit by "InfoSeeker" (Oct 26th 2021, 10:49pm)
knacker
Tuesday, October 26th 2021, 10:59pm
Thanks for that- I did look but obviously not hard enough as I can just make it out now that I've shined a torch to check :D :wacko:
