• 18.05.2026, 01:38
headbass
Aquasuite crashing on page loading after updating aquasuite
Monday, November 1st 2021, 10:12pm
Hello Aquacomputer,
I truly love the Aquasuite/Aquaero but more often then not when I update the Aquasuite my page stops working and Aquasuite crashes after loading it.
Would be great if I could get some support finding the cause of the crashing and fix it since it always takes me days to recreate the page ;o]]
In the event viewer I can see 2 erros related to Aquasuite:
Faulting application name: aquasuite.exe, version: 10.2.7912.16496, time stamp: 0x612c8442
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x00007fff1fda2b34
Faulting process id: 0x6da4
Faulting application start time: 0x01d7cef5f26a7ec6
Faulting application path: C:\Program Files\aquasuite\aquasuite.exe
Faulting module path: unknown
Report Id: 5e84b67f-2780-46af-bb39-cdf99f6d68a8
Faulting package full name:
Faulting package-relative application ID:
Application: aquasuite.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
at AquaComputer.Overview.LogDataControl.LogDataItem.LVthPEz4w4wOm6RHZWD(System.Object)
at AquaComputer.Overview.LogDataControl.LogDataItem.mvfiRTCfxf()
at AquaComputer.Overview.LogDataControl.LogDataItem.tW1ipd0lVw()
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart()
Attached:
XML export of my page attached (in rar)
Screen of some earlier page version
Any help would be greatly appreciated. Will gladly provide any requested info/logs.
If I can't solve it I am afraid I will just stop purchasing updates and just keep current version forever ;o[[
headbass has attached the following files:
  • 2021-11-01.rar (3.34 kB - 2,364 times downloaded - Last download: Yesterday, 9:19pm)
  • 2018-04-10_213933.jpg (694.14 kB - 397 times downloaded - Last download: May 16th 2026, 8:03am)
This post has been edited 1 times, last edit by "headbass" (Nov 1st 2021, 10:13pm)
Tuesday, November 2nd 2021, 7:47pm
Sorry to hear about your issue. I have been able to import your page at no issues.
Of course not all sensors are available at my system:
From a first look at the error log it looks like there is an System.NullReferenceException issue with a LogData Control.
It looks like you use a LogData chart of CaseBottom vs WaterOut.
You can try to remove the element in the XML page file manual and try again. Just delete the complete block.
We will also try to find the bug.
headbass
Wednesday, November 3rd 2021, 11:14pm
Thaaanks Stephan,
while removing the xml block using the "CaseBottom vs WaterOut" did not help when I removed all (there were 2 in total) block of
<itemType>LogData</itemType>
It now works again ;o]]
I have my page back, just with 2 graphs missing (which I can live with and recreate)
Would be great to have this fixed, but at least now I am able to keep updating my Aquasuite with little effort ;o]]
Thanks again for the quick reply and helpful advice
Matt
Thursday, November 4th 2021, 12:41pm
Glad to hear you have been able to fix it that way!
Looks like we also found a bug which will be removed in one of the next releases.
