• 09.11.2026, 04:13
OCTO issue or...
Thursday, November 11th 2021, 4:21pm
I do not know if I have an OCTO issue or something else.
Using 3 PWM ports on an OCTO (#2=pump, #3=pump, #7=fans)
  • set PWM port 2 (pump 1) to Power preset @ 85% {port2_set.jpg}
  • set PWM port 3 (pump 2) to mimic PWM port 2 (pump 1) {port3_set.jpg}
  • set PWM port 7 to a curve controller {port7_set.jpg}
  • execute a cold start
  • after cold start PWM port 2 has no issue {port2_restart.jpg}
  • after cold start PWM port 3 sets itself to Power preset at 0% {port3_restart.jpg}
  • after cold start PWM port 7 sets minimum temperature to 1 (from 2), the curve looks similar {port7_restart.jpg}
Friday, November 12th 2021, 7:14am
mybe an problem with different profile configurations?
Friday, November 12th 2021, 1:19pm
I have 3 local profiles on the OCTO, with the only difference being aRGB control.
  • normal: breathing color 1
  • low flow: blinking color 2
  • high Δt: blinking color 3
  • local profiles: {lp.jpg}
  • global profiles: {gp.jpg}
  • Initially I did have a Power preset on Pump 1, and 1° for the low temp on the fans
I believe I may have a problem with pump 1, it may be pulling too much current, which may have been the cause of the low voltage issue seen earlier.
I am still on an external power supply.
I am waiting on a new pump, but I may disconnect pump 1 from both power & control and see what happens with a single pump.
Pump 1 has been running, but it may have a high spike at start which results in low voltage to the OCTO
I do not know how low voltage effects the OCTO, but there may be an influence there.
As of this morning pump 2 is not operating.
Edit: I may have saved the Breathing profile with the initial Power preset and 1° low temp setting. I reloaded the updated settings to the profile and will see if that fixes that issue.
This post has been edited 1 times, last edit by "InfoSeeker" (Nov 12th 2021, 1:28pm)
WinstonWoof
Saturday, November 13th 2021, 8:59am
Why not swap the Pump headers 2,3 & 7 to say 4,5 & 6 , configure them as you have done now on 2.3 & 7 and see if the problem persists
FYI the max total load is 100W with each individual header being up to a max of 2o(or is it 25?) W
This post has been edited 1 times, last edit by "WinstonWoof" (Nov 13th 2021, 9:00am)
Saturday, November 13th 2021, 2:10pm
System start today had PWM port 3 (pump 1) at Power preset, and PWM port 7 (fans) low temp at 1°.
But I may have still erred, and I reset all 3 profiles again.
It would be very useful if there were a template available that listed all the settings a profile is set to.
I assume the profile settings are stored in the device's saved profile, but it is a long string sans labeling. {octo_profile_2021-11-13_06-50-35.rar}
Is there a profile save for the Playground?
There are a lot of settings there.
Pump 1 was originally on PWM port 1, and I moved it to port 3 to check port failure.
The problem appears to be with the pump, it looks like it is drawing too much current.
PWM port 7 has a splitty 9 on it with 9 Noctua 'NF-A14 industrialPPC PPC-2000 IP67' fans on it. Max power draw/fan = 2.16w * 9 = 19.44W total
The pumps draw power from a separate source, not from the OCTO, so power should not be an issue here.
WinstonWoof
Saturday, November 13th 2021, 2:39pm
Ahhhh :)
Are both the pumps the same make/model or different then?
I'm lucky in that he Pump on my EKWB Quanum FLT has a seperate power supply so all the octo does is PWM control rather than having to supply the full pump demand
Saturday, November 13th 2021, 3:16pm
Ahhhh :)
Both pumps are Aqua Computer D5 pump motor with PWM input and speed signal.
If a piece of gear has electrical or electronics involved, I use aquacomputer so as to minimize complications.
The aquacomputer D5 pumps, as most all D5 pumps I know of, have a separate 4-pin Molex connector for the 12 volt supply.
Regarding profiles:
In setting the OCTO's profiles I have to click on the profile I want to set.
This enables that profile as active.
Is there a setting that will make the Global Profile take over and control the profiles again, or do I have to always select the 'default' local device profile to start the Global Profile?
This post has been edited 1 times, last edit by "InfoSeeker" (Nov 13th 2021, 3:17pm)
