• 29.09.2026, 03:34
knacker
EK gpu/cpu block rgb control
Saturday, December 25th 2021, 1:29pm
Hi all
I currently have octo with D5 next pump, high flow and ultitubes leds connected and working good. I have EK cpu & gpu block and currently use Asus Aura rgb software but keep having issues with it crashing. Is it possible to use either the Octo or daisy chain the D5 next to control the blocks
Thx
Tasky
Sunday, December 26th 2021, 10:53am
So long as your EK kit has 3-pin 5v connectors on their RGB leads (which most do these days, I believe), you can get little RGBpx adapters that will connect an Aquacomputer lead to the EK kit and it will run just like any other RGBpx kit.
https://shop.aquacomputer.de/product_inf…roducts_id=3829
knacker
Sunday, December 26th 2021, 11:25am
Thanks for the reply- I wasn’t aware of these so have ordered a couple to try
Similar threads
