• 16.11.2026, 21:06
gvsykes
Converting flow sensor rpm into l/h data in aquasuite
Wednesday, December 29th 2021, 7:53pm
Hello all,
Just installed my new quadro and getting to grips with it.
In one of the 4-pin headers on the quadro i have connected a 3-pin connector from an alphacool flow sensor (tried to get the NEXT but out of stock and i just thought I would put it in and see what happens).
Basically what I am trying to do within aquasuite is take the rpm from the flow sensor, convert that into a L/h reading (using alphacool provided table) and then use that L/h "value" as an output to control the pump speed, which is also connected to the quadro.
Is this possible? I know it sounds like a very roundabout way of doing things but I figured I would give it a go.
Thanks for your time.
gassynizz
Monday, January 10th 2022, 2:48am
Well, are you getting a reading of rpm's to actually show up in aquasuite?
If yes, then you go to the playground and create a virtual sensor. Use the rpm as the input. Then use functions to make whatever conversions are required based on your table. Set your final result as the output. Now you can set fan speed based off the aquaservice virtual sensor.
If you're not getting rpm's from the cable recognized, then I don't know what to do.
Similar threads
