• 12.11.2026, 23:27
z00mantwo
Octo Flow Sensor
Sunday, January 23rd 2022, 5:13am
I am unclear on what are the proper flow sensors to use with an Octo and will plug in to the 3 pin flow sensor connection on the Octo. Any help would be appreciated.
Sunday, January 23rd 2022, 1:41pm
z00mantwo
Sunday, January 23rd 2022, 3:29pm
Thanks. That answers my questions and clarifies my options.
Just have to wait for one of them to be available for order.
z00mantwo
Thursday, January 27th 2022, 4:39am
Actually the "High Flow NEXT" connected via 3 pin cable to OCTO does not work. You get a flow number about 3 times bigger than actual flow. Just tried it.
Thursday, January 27th 2022, 7:33am
Wrong, this is working, you have to set up your sensor output signal in the alarm section.
z00mantwo
Thursday, January 27th 2022, 4:47pm
You are right. Thanks for the information. That fixed the output to the OCTO.
C47
Wednesday, February 2nd 2022, 11:37pm
I connected my HFN with that cable to my Octo (Flow connector) and my flow rate reading from HFN disappeared and what I got on Octo was wildly different.
Without the cable, for some reason Octo isnt able to get the flow rate on its sensor (I had assumed it would get it from the software side of things automatically, but it looks like its only able to read from the connector)
Thursday, February 3rd 2022, 12:54am
Read the 3 posts prior to yours and see if that helps.
Edit: If you have both HFN & octo on usb, you can import the flow rate from the HFN to a Soft. Sensor on the octo, and the flow rate will be available to the octo.
This post has been edited 1 times, last edit by "InfoSeeker" (Feb 3rd 2022, 3:09am)
