• 02.10.2026, 18:08
C47
Leakshield : TESTER mode
Monday, January 31st 2022, 2:57am
How long do I have to run the TESTER mode? For about 10mins in, one screen it shows me Pressure as - - - (I dont know why) and leak rate as 0.1-0.5mbar/min (system is off). The secon screen shows 291.9mbar.
There is nothing in the manual or FAQ about how long to run it.
I am assuming it is fluctuating due to temp changes or very minor leaks in fittings as they are not 100% vacuum proof.
Also is it correct to assume 0.5mbar/min is safe to power up and system and test further?
RBMDragon
Wednesday, February 2nd 2022, 11:55am
I have similar questions, but the fluctuations are 0.3mbar/min to -0.3mbar/min, stabilizing near 0.0 to 0.1mbar/min.
The pressure is dropping over time although very slowly.
What are the criteria for a proper seal?
I've noticed the Shield Alarm values ranging from 50ml/h to 150ml/h.
Are these values representative indicators in terms of initial airtight seal?
RBMDragon
Saturday, February 5th 2022, 10:15am
I've managed to seal the system.
The Ultitube O-ring and Leakshield was finicky.
I ended up going through the entire system and did some other corrections so tensions wouldn't be present.
System is up and running, ran overnight with liquid in it and the pump running.
