• 30.09.2026, 17:50
Flow accuracy
Monday, February 7th 2022, 3:25pm
Pleased to see the High Flow Next and the analog flow meter are in agreement.
Monday, February 7th 2022, 4:35pm
This result is with the High Flow Next mounted vertically (octo & hubby in the j-box).
Monday, February 7th 2022, 11:09pm
When people are talking about flow meter accuracy I like to steer them to this Igor's Lab Review of the Aquacomputer High Flow verses the Thermaltake TF1 verses the Barrowch FBFT03 verses a Keyence FD-Q10C high precision flow meter. Spoiler Alert - The Aquacomputer High Flow matches the Keyence FD-Q10C high precision flow meter almost perfectly while the Thermaltake and Barrowch were so bad that you might as well not bother looking at them. The Thermaltake readings are consistently way too low while the Barrowch starts out too low then quickly changes to way too high. They are both so far off that the author of the review said, "the deviations of both flow sensors (Thermaltake and Barrowch) are so extreme that they simply should not be used".
The original article is in German and the English translation is a little rough but understandable. The Barrowch FBFT03 shows up in a lot of custom loop builds and the owners sometimes get mad when I show them this article. No one likes to find out the flow meter they bought is totally inaccurate. I would never consider buying a flow meter from anywhere other than Aquacomputer. Kudos on another great product.
mditsch
Tuesday, February 8th 2022, 6:17am
[When people are talking about flow meter accuracy I like to steer them to this Igor's Lab Review of the Aquacomputer High Flow verses the Thermaltake TF1 verses the Barrowch FBFT03 verses a Keyence FD-Q10C high precision flow meter. Spoiler Alert - The Aquacomputer High Flow matches the Keyence FD-Q10C high precision flow meter almost perfectly while the Thermaltake and Barrowch were so bad that you might as well not bother looking at them. The Thermaltake readings are consistently way too low while the Barrowch starts out too low then quickly changes to way too high. They are both so far off that the author of the review said, "the deviations of both flow sensors (Thermaltake and Barrowch) are so extreme that they simply should not be used".
Nice. I've both in my loop: HF and High Flow Next. One is directly followig the other (first HFN then HF) with enough tubing in between.
The results you can see in the graph (act values: 70.8l/h for the HF, 75.5l/h for the HFN). Above one is for HF and the below one is for the HFN. Flow ist held at 75l/h. Which one should I trust now more?
mditsch has attached the following image:
This post has been edited 5 times, last edit by "mditsch" (Feb 8th 2022, 7:18am)
Tuesday, February 8th 2022, 7:10am
Isn't that obvious after Igors Lab's test?
mditsch
Tuesday, February 8th 2022, 7:13am
Why? I won't believe that AC has released a new sensor which will be much less accurate then an older model?
This post has been edited 2 times, last edit by "mditsch" (Feb 8th 2022, 7:15am)
Tuesday, February 8th 2022, 7:15am
the high flow NEXT is the tested one ;-)
mditsch
Tuesday, February 8th 2022, 7:16am
YEAHH. I pointed to the wrong test. I mentioned the other one from the text below https://www.igorslab.de/barrowch-fbft03-…wasserkuehlung/
corrected now
This post has been edited 1 times, last edit by "mditsch" (Feb 8th 2022, 7:19am)
Tuesday, February 8th 2022, 7:29am
the NEXT is better. The NEXT sensor corrects the flowwith a no linerar correction in every flow range.
The HFN is very linear, especially in the lower range (<100 l/h) where there are otherwise larger deviations.
mditsch
Tuesday, February 8th 2022, 7:46am
but for what I'm wondering: based on the test of the High Flow, in which The HF (without next) was very very close to the reference value is it now too much away from the High Flow Next in my loop. It's always ca 5l/h. That's a little bit confusing me.
This post has been edited 2 times, last edit by "mditsch" (Feb 8th 2022, 7:47am)
Grestorn
Tuesday, February 8th 2022, 8:29am
To me it looks like the old HF flow measured is temperature-dependent. How else would you explain the decrease in flow as shown on your diagram? You didn't change the pump speed, did you?
Usually, the flow increases with the water temperature, not decrease. And certainly not to this amount.
mditsch
Tuesday, February 8th 2022, 8:44am
no I haven't changed anything. The two flowmeters are direclty the one behind the other. the difference between them two are always near 5l/h.
