• 14.11.2026, 09:17
nighteagle123
leakshield thin walled tubes limit?
Sunday, March 13th 2022, 12:12pm
I can see the leakshield requirements says : All components in the cooling system must be qualified for the configured negative pressure. Especially soft, thin walled tubes are not suitable
Can I use my current tubes with leakshield? I am using:
EK-DuraClear 9,5/12,7mm 3M RETAIL
https://www.ekwb.com/shop/ek-duraclear-9-5-12-7mm-3m-retail
Thanks in advance for any answers you might provide.
Sunday, March 13th 2022, 2:21pm
I tried different 12/10 er hoses, the result always remained the same.
The hoses have contracted first on bends and over time also on straight.
I would therefore recommend switching to 16/10 or acrylic/PETG.
Of course, it also depends on the vacuum used, if you use a system with low pump power it may work.
