• 11.10.2026, 01:24
IIISLIDEIII
aquaero 6LT or octo
Tuesday, March 15th 2022, 1:03am
I am undecided whether to buy octo or aquaero 6 lt, can someone tell me what are the more things I would get with aquaero compared to octo?
can aquaero drive 3-pin ddc pumps no pwm?
also I would like to create a fan curve around the delta instead of the water temperature and I have read that only the Aquaero can do the equation and work after being configured, even with the software uninstalled or USB unplugged.
The octo will allow you to save the curve to the device and if you are just using Water Temp it will continue to work perfectly after being configured, even if you unplug it from the USB header, but for creating a curve around a Delta T Temp the software should remain installed and the USB connected, unlike the Aquaero which can do the calculations on board.
It's right?
Tuesday, March 15th 2022, 8:15am
The OCTO has only PWM connections, so can not control via 3Pin and the voltage.
The sense of a delta control times leaving aside the Aquaero can calculate a delta, with directly connected sensors, I can not say anything about the OCTO, because I do not own one.
Both devices do not need the software for operation, as long as all sensors are connected directly and no software sensors are used, they run as set as long as they get power.
Translated with www.DeepL.com/Translator (free version)
IIISLIDEIII
Tuesday, March 15th 2022, 5:09pm
thanks, can aquaero control 3 pin pumps?
Tuesday, March 15th 2022, 5:13pm
that depends on the pump
The key features of the aquaero 6 include:
· Programmable four channel fan controller
· USB 2.0 and aquabus interface
· Four fan outputs with up to 30 Watt of power per channel
· All fan outputs with 4-Pin plug, switchable between voltage and PWM control
· Versatile control options
· Eight temperature sensor inputs
· Flow sensor input
· Three LED outputs
· Potential-free switch
· Two additional power outputs
· Extensive alarm options
· Acoustical alarm
· Speed signal output for status evaluation
· Expandable to a maximum of 12 fan channels
For a more thorough feature description, we recommend to download the manual: aquaero_5_aquaero_6_english.pdf
Remayz
Tuesday, March 15th 2022, 8:47pm
Edit : dired.. i derped
This post has been edited 2 times, last edit by "Remayz" (Mar 15th 2022, 8:58pm)
