• 15.11.2026, 12:01
knacker
Gasket for Leakshield
Friday, March 18th 2022, 3:37pm
Seems that I was missing the gasket for the leakshield as I dont remember seeing on in the box so probably why it cannot create enough pressure
Can anyone tell me where or what the gasket can be ordered/replaced pls
UK based if that makes a difference ;(
Friday, March 18th 2022, 10:18pm
If the Gasket is missing from the kit, contact Support, they may make you good.
r3volt97
Saturday, March 19th 2022, 8:30pm
The bottom gasket which supposedly goes in between the bottom of the Ultitube and the pump ? I found my gasket inside the tube itself alongside the fixation ring ( vibration dampener ) .
Not sure but i think it's just an o-ring like this big ? Mine is loosing pressure as well , i have the beefy gasket on the bottom since when i had it on top of the Leakshield it was leaking from the bottom
https://www.aquatuning.co.uk/water-cooli…-for-leakshield
