• 12.11.2026, 16:44
hooj
aquastream error
Monday, January 17th 2005, 10:44am
I have an aquastream 3.0 pump in my system, which I have has setup for the past 3 days.
However yesterday the pump stopped working. The control panel flashed red 4 times consecutively, which according to the manual means "short circuit at the pump or cable".
What does this mean? Are there any places i should be checking?
I have taken off the pump power cable and inspected both it and the panel, but nothing is different to when it was working.
Any ideas?
Nitrix
Re: aquastream error
Monday, January 17th 2005, 6:36pm
OH O,
another person i know had this problem and in the end they had to buy a new pump..... :-[ :'(
hooj
Monday, January 17th 2005, 7:13pm
Yeah, i've seen the same problem both here and over a wizdforums.co.uk.
Bit of a bummer if I have to replace pump. The systems been out of action for long enough.
Nitrix
Tuesday, January 18th 2005, 2:17am
RMA the pump back to where you brought it from 8)
hooj
Friday, January 21st 2005, 12:28pm
Quoted from "Nitrix"
Well I sent an email over 2 support@aqua-computer.de on monday and another one yesterday. No reply yet. :-[
How long do they normally take to get back to you?
Jogibaer_Nr1
Friday, January 21st 2005, 12:47pm
It's not regular......but I can suppose to you, that the Aqua-Computer support is working the fastest way to send an answer to you! ;)
hooj
Monday, January 24th 2005, 6:20pm
Just a quick update.
Couldnt find out what the problem was so I have arranged an RMA with www.leftclicks.co.uk who, even though I didn't purchase the pump from them have arranged to RMA mine and send me a replacement.
Top stuff!
