• 01.10.2026, 09:31
schiaffo88
High Flow Meter switchoff problem
Tuesday, April 12th 2022, 10:33am
Hello,
although I have the auto shutdown Flag via USB, the FlowMeter does not turn off with the PC, activating the Alarm Signal below 30L / h ...
How can I fix the USB signal shutdown problem?
schiaffo88 has attached the following images:
This post has been edited 1 times, last edit by "schiaffo88" (Apr 12th 2022, 10:36am)
Shojiro
Tuesday, April 12th 2022, 4:58pm
Do you have the cable that connects from the High Flow NEXT to the motherboard power switch header as seen here?
As per the high flow next manual, it says this under the signal connector:.
Utilization as alarm output - The header can be connected to the power switch header of the motherboard us-ing an additional specialized cable (53216, not included in delivery)
I definitely read the first post wrong, sorry. Ignore the above
This post has been edited 1 times, last edit by "Shojiro" (Apr 12th 2022, 8:02pm)
Hufeisen
Tuesday, April 12th 2022, 6:18pm
Maybe you need to select "disable alarm detection" in the Aquasuite software.
Hufeisen has attached the following file:
