• 30.09.2026, 23:48
Norton
D5 Next pump - not working?
Monday, April 18th 2022, 5:47pm
Hi all, just finished my new build with remote rad and d5 next pump/Res however on the first power up it's giving me nothing other than red lighting. The pump won't turn and the screen isn't working.
Any ideas?
Thank you in advance.
Monday, April 18th 2022, 6:00pm
Is the power cable plugged in correctly and are the electronics firmly seated on the pump?
Simply disconnect and reconnect both.
Is the D5 in the computer or on the external radiator?
If it is external, with what kind of power supply?
Norton
Monday, April 18th 2022, 6:11pm
Yup everything is seated correctly. Like I say, the RGB ring lights up red but there's no other signs of life. It is external and powered by a phobya molex PSU. Its wattage rating should exceed the power draw of the pump and three fans I intended to use (Inc start up power draw).
Monday, April 18th 2022, 6:17pm
Then test if it works on the power supply of your computer, if it doesn't work there either and you have already disconnected the electronics it is probably a case for the support.
Norton
Monday, April 18th 2022, 6:34pm
Thank you.
Tried my PC's PSU, now I have a spinning pump but still no screen and now no lit up RGB ring as well ..
This post has been edited 1 times, last edit by "Norton" (Apr 18th 2022, 6:49pm)
Tuesday, April 19th 2022, 11:51am
The external Phobya power supplies have repeatedly been blamed for being extremely bad.
There is a chance, that it damaged your pump.
Norton
Tuesday, April 19th 2022, 12:18pm
Bugger. Time to buy another then I guess.
Tuesday, April 19th 2022, 2:28pm
Maybe this is enough, the pump itself works.
https://shop.aquacomputer.de/product_inf…roducts_id=4044
