• 08.10.2026, 01:11
Tenno6
So I guess I just wont get support then?
Sunday, May 8th 2022, 2:33am
Seriously annoyed that I've gotten zero support for my post and am sitting here with a broken OCTO or broken software. Cant make changes to the fan speeds (stuck at 100) and closing and reopening the software just resets everything back to power preset. Not that power preset actually matters because it seems the damn software can't actually tell the octo to actually do anything anymore.
Sunday, May 8th 2022, 6:57am
This is not a support forum of the manufacturer, here the users help each other.
So you can't expect that your problem will always be solved.
Quote: "Please do not post personal support requests in our forum. We will not be able to provide appropriate answers there for privacy reasons."
If you want direct support just send a mail to: support@aqua-computer.de
One more tip, if you want an answer you should provide much more information, like screenshots of the settings.
This post has been edited 1 times, last edit by "Taubenhaucher" (May 8th 2022, 6:59am)
hossam.sy
Sunday, May 8th 2022, 8:03am
Did you try to troubleshoot it first? I would do this:
Remove all fans except one that you're sure is ok, remove other connections except usb and try to connect it to the single usb outlet without a hub, force reinstall firmware, see if there is liquid or something blown up in the board, try it now and walk your way up adding more devices and fans if it works ok with one fan.
I mean I have always had problem with AC stuff but it turns out to be a connection mistake I made.
Tenno6
Sunday, May 8th 2022, 4:34pm
Of course I've tried troubleshooting it. I've done all that except
forcing firmware reinstall because I can't figure out anyway to do that.
Clicking install fw just says already up to date.
The
connections aren't the problem... Before troubleshooting I hadn't
changed anything and it has been fine for a year. Closing and reopening
the software resets all the octo settings to default.
This post has been edited 1 times, last edit by "Tenno6" (May 8th 2022, 4:52pm)
hossam.sy
Sunday, May 8th 2022, 4:40pm
Well contact AC support via email and they would tell you if there is any solution or if you have to send the device to them for repair.
hossam.sy
Sunday, May 8th 2022, 6:36pm
One last thing I would check if you didn't, try to use different molex plug from another PSU line
Similar threads
