• 19.11.2026, 17:18
Undesirable
EasyAntiCheat Game Security Violation [AquaComputerService.exe]
Sunday, May 22nd 2022, 10:29pm
The game Lost Ark keeps randomly kicking me out to the desktop several times per day with this message:
This post has been edited 1 times, last edit by "Undesirable" (May 22nd 2022, 10:32pm)
Monday, May 23rd 2022, 12:48am
You may want to contact support @ easy anti-cheat. It sounds like they are pinging a false positive on aquacomputerservice.exe
Monday, May 23rd 2022, 6:56am
Have you tried disabling audio and video analysis under aquasuite -> audio and video?
Undesirable
Thursday, May 26th 2022, 3:12am
Thanks, I've turned this option off and I'll see what happens.
Undesirable
Friday, May 27th 2022, 2:51pm
Unfortunately the Security Violation error happened again whilst those options were turned off.
Friday, May 27th 2022, 2:56pm
Then try the other hardware monitor settings, first I would turn off the GPU and CPU monitoring and see what happens.
I don't have the problem, but also only use the monitoring of the HDD/SSD, the rest of the values come from HWInfo64.
Friday, May 27th 2022, 5:47pm
I would also contact support at easy anti-cheat... they need to make an exception for whatever triggers them on AquaComputerService.exe
Undesirable
Saturday, May 28th 2022, 3:47am
Thanks, I might just do that InfoSeeker & Tabenhaucher.
All I have switched on is CPU & GPU monitoring right now. It could be happening less frequently, not sure yet.
Saturday, May 28th 2022, 10:01am
These are exactly the two values that most likely cause the problems.
Undesirable
Monday, May 30th 2022, 1:53am
Probably, but those are also the two values that I need monitored most! :S
