• 03.10.2026, 06:29
Ytterbium
Auto invert not inverting on HighFlow Next
Friday, May 27th 2022, 3:24pm
Hello,
I mounted my high flow upside down so I selected the rotate option, I left the default to rotate the screen and colors but it never seems to change from inverted to default.
Any suggestions no how to restore the expected functionality?
Friday, May 27th 2022, 6:13pm
Rotate & Invert are two separate functions
  • Rotate physically rotates the display 180° to match your Flow NEXT's upside down orientation
  • Invert toggles the pixels in the display between black and white (immediately)
  • Auto invert switch the pixels at a predetermined period (do not know the timing)
Ytterbium
Friday, May 27th 2022, 6:47pm
OK, could be that the auto invert just did not do it in the time frame I expected. I thought it did one cycle of display in light then one cycle in dark but it could be something else as you say.
Thanks for the comments
