• 02.10.2026, 07:26
ronzino
Leakshield negative leak indicator
Friday, June 17th 2022, 1:35am
What does it means when the water leak indicator is negative ? and when it is positive ?
I can experiene both and it seems to me that is water temperature related
Ytterbium
Friday, June 17th 2022, 7:25am
Normally air will leak into the system so this is a positive leak indication. As you say it can be when the water temperature changes the volume of water changes which leads to a decrease in pressure ( more mbar vacuum since its in bar gauge) this is reported as a negative leak indication.
