• 11.10.2026, 23:00
lingyu
ULTITUBE D5 NEXT Alarm and Water pump fails to operate
Saturday, June 18th 2022, 12:21pm
Today, I turned on the computer and found that D5 NEXT reported an error. I took out the water pump and started it with an external power supply. I found that the water pump could not run
Switching the water pump mode makes it impossible to operate
Alarm: pump speed too low
How to detect whether there is a problem with the pump body or the electric control board?
This post has been edited 1 times, last edit by "lingyu" (Jun 18th 2022, 2:40pm)
RBMDragon
Tuesday, June 21st 2022, 12:21pm
I hope you didn't run the pump dry.
(It needs water as lubrication, or else the impeller gets damaged)
