• 30.11.2026, 22:34
Canard_Coincoin
Quadro/Octo : need aquasuite always on ?
Tuesday, June 28th 2022, 12:16pm
Hi All,
I understand that Aquasuite will provide setup functionalities in order to, for example, setup fan speed curve based on sensor temp.
I would like to know if, once the setup is done, it is saved in the Octo/Quadro or if it will still require Aquasuite software to load in order to follow the fan speed/sensor temp curve ?
In other words : I do the setup with Aquasuite running on windows. I reboot under Linux => how will my fans behave ?
Thanks for answers !
Remayz
Tuesday, June 28th 2022, 12:47pm
if your setup doesn't rely on aquasuite feeding software sensors to the octo yes.
Basically, if you use temperature sensors hardwired to the octo, it will work.
Anything involving hardware monitoring or virtual sensors won't work.
So if you have a custom loop with water temp sensor connected to the octo, you're good to go.
air cooling, you can strap sensors to whatever component heats up your rig, usually somewhere around the GPU, and connect to the Octo.
Canard_Coincoin
Tuesday, June 28th 2022, 1:46pm
Wow great functionality, and thanks for quick answer. :)
So just to be sure :
- I connect a hardware sensor for water temp to a quatro
- I connect a fan to the quatro
- I setup a curve in aquasuite where fan speed is based on water temp
If I reboot under Linux, the fan will still follow the curve previously defined ?
This post has been edited 1 times, last edit by "Canard_Coincoin" (Jun 28th 2022, 1:47pm)
Remayz
Tuesday, June 28th 2022, 2:40pm
yep. Quadro and Octo have 4 hardware profiles. you just save the fan curve on them (or just on the default first one) and it will run off it if aquasuite doesn't run. same goes for the LED channel(s). they are saved in there.
Canard_Coincoin
Tuesday, June 28th 2022, 2:56pm
Excellent, thanks a lot ! :thumbsup:
Similar threads
