• 05.10.2026, 14:40
M3TAl
RGBpx LED(53270) not working
Tuesday, July 5th 2022, 4:56pm
Had this LED strip unused for a year+ but never tested it. I assume it was working. I cut it to fit in a monoblock and hooked it up to an OCTO. No joy, it doesn't turn on.
I would have to drain the loop and remove the monoblock to get access to the LED. I do have the other end that was cut off. That specific strip has connectors on both ends.
Any ideas?
M3TAl
Wednesday, July 6th 2022, 1:02am
So just now while trying to disconnect the 4cm RGBpx connection cable from the strip it completely ripped off... It was probably already bent to the point of messing up the connection.
On the plus side the other end that was not in use works, just tested it. Now I'll have to drain the loop and remove the monoblock again :(
