• 12.11.2026, 00:18
Xeroeth
Automatic profile change basing on ambient temp
Saturday, July 23rd 2022, 9:09am
Hello, I'm trying to setup the automatic profile to load 2 diffirent profiles, based on ambient temperature. What I'm trying to do is set the 1 profile if the ambient is 26'C or below and profile 2 when it's 27 or above. I want it to change automatically if the temperature falls bellow or rises above those trigger temps. I have created the rules like below and it doesn't change automatically ... am I missing something?
Profiles
Rules
This post has been edited 1 times, last edit by "Xeroeth" (Jul 23rd 2022, 9:13am)
CASE: TT CORE X9 || MOBO: ASUS X99-A II || CPU: I7-6800k@4.2GHz || GPU: EVGA 3080 FTW3 || RAM: G.SKILL TRIDENT Z 64GB@3000MHz
WinstonWoof
Saturday, July 23rd 2022, 10:27am
Use 2 Output steps from Playground
One to trigger on and one to trigger off
Eg this one triggers my Max Fan Profile if Ambient >= 25
You then need a second one to switch to a another profile if ambient <25
UPDATE:
Well theoretically
just having a play using CPU Delta instead and although it switches to the Max Profile it doesnt switch back
hmmmm
UPDATE 2
Yes it does work. Had to enable on Global Auto Fan Profile Switching as well
This post has been edited 3 times, last edit by "WinstonWoof" (Jul 23rd 2022, 10:50am)
WinstonWoof
Saturday, July 23rd 2022, 11:27am
Xeroeth
Saturday, July 23rd 2022, 9:16pm
Thank you, with 2 outputs it works like a charm :)
This post has been edited 1 times, last edit by "Xeroeth" (Jul 23rd 2022, 9:17pm)
Caldorian
Monday, July 25th 2022, 9:45pm
This is an interesting concept in using outputs for profile switching instead of the global profile rules.
When would you use each? And if you used both, would the global rules end up overriding the output switching?
WinstonWoof
Monday, July 25th 2022, 11:52pm
TBH I simply did it as a POC in response to the OPs question lol
Remayz
Tuesday, July 26th 2022, 12:23am
I wonder if the fact that there was a 1°C gap between the two profiles where nothing happens could have caused issues. Software usually don't like grey areas :p
WinstonWoof
Tuesday, July 26th 2022, 8:03am
Ah Yes I hadnt seen that in the OPs original post.
When I did it my way the On trigger was >=40c whilst the Off was <40c to avoid any greyness
