• 29.11.2026, 00:42
Jubijub
How to control A-RGB lights ?
Friday, July 29th 2022, 11:53pm
Hello,
I am lost on which Aquacomputer product to use to achieve this.
I have an Aquaero 6, a bunch of other devices (Ultitube Next, high flow next, etc…)
I also have a bunch of devices with A-RGB (Noiseblocker fans, EKWB blocks lights.)
I would like to control A-RGB lights based on delta-T calculated by the Aquaero.
Which products shall I use in between ?
I need some sort of splitter that offers multiple RGBpx channels (since I have 2 loops, I want to control 2 groups of lights), and “something” to control those channels from the Aquabus (maybe the ultitubes / high flow next can do that?).
I have found the RGBpx -> A-RGB converters
In total I would like 2 groups as follows :
CPU group :
- 1x ultitube
- 1x high flow next
- 2x Noiseblockers
GPU group :
- 1x ultitube
- 1x high flow next
- 2x EKWB terminals (water block + active plate)
- 4x Noiseblockers
I have A-RGB splitters from EK, so both groups end up as 1 A-RGB cable.
Thanks for your help,
Julien
Remayz
Saturday, July 30th 2022, 12:29am
well.. for ARGB there's only the Farbwerk360 but it's USB only afaik. The Octo and quadro only serve as fan controllers in Aquabus i believe.
Any reason to not use aquasuite to transmit the data through USB?
Jubijub
Saturday, July 30th 2022, 10:28am
Thanks for your reply.
My reason (which is why I got an AQ6 in the first place) is that I use my computer 50-50 between windows and Linux (Arch), and to my knowledge there is no aqua suite for Linux?
If it did exist I would rely just on USB and ditch the Aquabus, but it doesn’t seem like an option ? (I’d be happy to be proven wrong
pagusas
Saturday, July 30th 2022, 7:01pm
The Octo has 2 ARGB ports for supporting ARGB in aquasuite. I do exactly what the OP wants, just with my CPU temp instead of Water temp. To do what you'd want OP, an OCTO would work + setting up a virtual sensor in the sensors section and setting the RGBpx section to Color Switch (where the colors change base on sensor input). Then define your range and color values.
This post has been edited 1 times, last edit by "pagusas" (Jul 30th 2022, 7:14pm)
Remayz
Saturday, July 30th 2022, 9:14pm
the product page for the Octo doesn't say the Aquaero can control its RGB ports through Aquabus, that's why i don't think it would work.
Otherwise yes, through USB, and windows only, it works fine.
Jubijub
Saturday, July 30th 2022, 9:55pm
Sounds good, Octo it is then !
Thanks!
Remayz
Saturday, July 30th 2022, 10:24pm
https://www.aquacomputer.de/tl_files/aquacomputer/downloads/manuals/aquaero_5_aquaero_6_english.pdf
look at page 39.
I don't own an aquaero so i can't test, but it seems that through aquabus, only the fan outputs, and the temp and flow inputs are controllable. but not the ARGB outputs.
Jubijub
Saturday, July 30th 2022, 10:34pm
look at page 39.
Hum…
The Octo manual also makes no mention of this.
So it would appear there is no Aquabus solution, only USB, which requires Windows :(
Remayz
Saturday, July 30th 2022, 11:22pm
i have vague memories of a post by someone from AC saying aquabus was too slow for the amount of traffic required for RGBpX, but i can't find where it was.
But.. the Octo will still be able to run ARGB without windows with control from its on board sensors, (but not on delta T obviously).
Sunday, July 31st 2022, 12:45am
i have vague memories of a post by someone from AC saying aquabus was too slow for the amount of traffic required for RGBpx, but i can't find where it was.
I also recall Aquacomputer stating that Aquabus has insufficient bandwidth for RGBpx data. I do wonder how much data actually runs back and forth between Aquasuite and the controller when its just sitting there playing back a preset. When you configure a preset, Aquasuite pushes that data across USB, but once its in the device, it does not seem like there would be that much data going back and forth. This excludes having things like virtual sensors or temps not local to the Octo control the LEDs. For that you need Aquasuite running and USB connected.
If you just want basic solid colors, or presets that do not require external data or virtual sensor output, I think that once you configure that preset, the Octo will just start playing it when it boots up. I know the Farbwerk360 does this. My LEDs controlled by a Farbwerk360 start doing their thing as soon as the Farbwerk360 and the LEDs have power. The presets I have set up do not involve virtual sensors or data sources not local to the Farbwerk360. The Octo ports are probably the same. I have an Octo, but am not using the RGBpx ports on it so I don't know for sure. I think it you connect the Octo via USB, boot into Windows, run Aquasuite and set up presets that do not require external data or derived data (virtual sensor), then shut down, remove the USB connection and boot into Linux, the Octo RGBpx ports should start playing back those presets.
Jubijub
Sunday, July 31st 2022, 11:19am
I bought an AQ specifically for the “doesn’t require drivers or specific OS, set it up once and it works independently.
I don’t blame Aquacomputer for not expanding this to RGBpx, it’s probably a super niche market and for most users having the Aquasuite service running in the back is perfectly acceptable.
Oh well, I’ll have static lighting I guess.
Remayz
Sunday, July 31st 2022, 2:59pm
you could pop in another in line temperature sensor to the loop connected to the octo, and have that temperature vary the RGB lighting.
It wouldn't be delta T, but it would react the same, just not on the same scale. that's probably the closest solution
