• 09.11.2026, 13:41
dfmastin
Not enough USB 2.0 headers
Monday, August 29th 2022, 2:28am
I purchased a NZXT Internal USB Hub 3 that works quite nicely except it does not pass power though to the headers when the computer is off/standby such that my Leakshield can’t do it’s job.
Does anyone know of a usb 2.0 splitter that will pass through power when the computer is off/standby.
Note: without the splitter my motherboard’s usb 2.0 passes power through when off/standby just fine. Problem is I only have one head which I can use for two devices, but I have a Leakshield, NEXT high flow, and Octo.
Monday, August 29th 2022, 5:50am
Hubby7
Quoted
If power is supplied via USB, depending on motherboard configuration, power will also be supplied during standby of the PC
Edit: do NOT use the SATA power connector
This post has been edited 1 times, last edit by "InfoSeeker" (Aug 29th 2022, 5:53am)
dfmastin
Monday, September 5th 2022, 7:05pm
Thanks so much InfoSeeker.
My new Hubby7 is working perfectly as intended.
Similar threads
