• 18.11.2026, 16:24
WaterBoy61
X.58 is denied by Kaspersky Internet
Monday, September 26th 2022, 10:18pm
Kaspersky says Aquasuite is a trojan. I cannot allow Aquasuite to install. And I tried to install Aquasuite by turning off Kaspersky. It still terminates Aquasuite.Today, 9/26/2022 3:40:46 PM Task started avp.exe C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 21.3 NT AUTHORITY\SYSTEM System user
Today, 9/26/2022 3:39:57 PM Task stopped avp.exe C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 21.3 NT AUTHORITY\SYSTEM System user
Today, 9/26/2022 3:36:50 PM Object deleted aquasuite-setup.exe aquasuite-setup.exe C:\Users\Internet\AppData\Local\Temp 11836 DESKTOP-OABC9DE\Internet Active user Deleted: PDM:Trojan.Win32.Bazon.a Deleted PDM:Trojan.Win32.Bazon.a Trojan High Exactly aquasuite-setup.exe aquasuite-setup.exe c:\users\internet\appdata\local\temp Process
Today, 9/26/2022 3:36:50 PM Process terminated aquasuite-setup.exe aquasuite-setup.exe C:\Users\Internet\AppData\Local\Temp 11836 DESKTOP-OABC9DE\Internet Active user Terminated: PDM:Trojan.Win32.Bazon.a Terminated PDM:Trojan.Win32.Bazon.a Trojan High Exactly aquasuite-setup.exe aquasuite-setup.exe C:\Users\Internet\AppData\Local\Temp Process
Today, 9/26/2022 3:36:50 PM Malicious object detected aquasuite-setup.exe aquasuite-setup.exe C:\Users\Internet\AppData\Local\Temp 11836 DESKTOP-OABC9DE\Internet Active user Detected: PDM:Trojan.Win32.Bazon.a Detected PDM:Trojan.Win32.Bazon.a Trojan High Exactly aquasuite-setup.exe aquasuite-setup.exe c:\users\internet\appdata\local\temp Process Databases
Today, 9/26/2022 3:33:16 PM Object deleted aquasuite-setup.exe aquasuite-setup.exe C:\Users\Internet\AppData\Local\Temp 6064 DESKTOP-OABC9DE\Internet Active user Deleted: PDM:Trojan.Win32.Bazon.a Deleted PDM:Trojan.Win32.Bazon.a Trojan High Exactly aquasuite-setup.exe aquasuite-setup.exe c:\users\internet\appdata\local\temp Process
Today, 9/26/2022 3:33:16 PM Process terminated aquasuite-setup.exe aquasuite-setup.exe C:\Users\Internet\AppData\Local\Temp 6064 DESKTOP-OABC9DE\Internet Active user Terminated: PDM:Trojan.Win32.Bazon.a Terminated PDM:Trojan.Win32.Bazon.a Trojan High Exactly aquasuite-setup.exe aquasuite-setup.exe C:\Users\Internet\AppData\Local\Temp Process
Today, 9/26/2022 3:33:16 PM Malicious object detected aquasuite-setup.exe aquasuite-setup.exe C:\Users\Internet\AppData\Local\Temp 6064 DESKTOP-OABC9DE\Internet Active user Detected: PDM:Trojan.Win32.Bazon.a Detected PDM:Trojan.Win32.Bazon.a Trojan High Exactly aquasuite-setup.exe aquasuite-setup.exe c:\users\internet\appdata\local\temp Process Databases
Today, 9/26/2022 3:31:51 PM Object deleted aquasuite-setup.exe aquasuite-setup.exe C:\Users\Internet\AppData\Local\Temp 10592 DESKTOP-OABC9DE\Internet Active user Deleted: PDM:Trojan.Win32.Bazon.a Deleted PDM:Trojan.Win32.Bazon.a Trojan High Exactly aquasuite-setup.exe aquasuite-setup.exe c:\users\internet\appdata\local\temp Process
Today, 9/26/2022 3:31:50 PM Process terminated aquasuite-setup.exe aquasuite-setup.exe C:\Users\Internet\AppData\Local\Temp 10592 DESKTOP-OABC9DE\Internet Active user Terminated: PDM:Trojan.Win32.Bazon.a Terminated PDM:Trojan.Win32.Bazon.a Trojan High Exactly aquasuite-setup.exe aquasuite-setup.exe C:\Users\Internet\AppData\Local\Temp Process
Today, 9/26/2022 3:31:50 PM Malicious object detected aquasuite-setup.exe aquasuite-setup.exe C:\Users\Internet\AppData\Local\Temp 10592 DESKTOP-OABC9DE\Internet Active user Detected: PDM:Trojan.Win32.Bazon.a Detected PDM:Trojan.Win32.Bazon.a Trojan High Exactly aquasuite-setup.exe aquasuite-setup.exe c:\users\internet\appdata\local\temp Process Databases
Today, 9/26/2022 3:29:55 PM Task started avp.exe C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 21.3 DESKTOP-OABC9DE\Internet Active user
Today, 9/26/2022 3:29:07 PM Task stopped avp.exe C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 21.3 NT AUTHORITY\SYSTEM System user
GMdoghunter
kaspersky and aquasuite
Tuesday, September 27th 2022, 2:23am
Sorry i cannot be of really any help with this,but i had to end up going away from kaspersky because of this,kaspersky support already knows that this is a false positive,it just doesnt seem to like aquasuite at all.
I ended up having to change my security suite because of this.
The only thing i can recommend to see if it works in your case is to exclude the scanning of aquasuite in kaspersky,basically making it ignore scanning aquasuite as recommended by kaspersky support to me when i had the issue,it didnt work for me,but hopefully it can work in your case.
Sorry i cannot be of any more help,but i can assure you it is a false positive that kaspersky also knows about as well.
Mr Gerard M Stadalius
WaterBoy61
Tuesday, September 27th 2022, 1:31pm
I tried to get Kaspersky to ignore the warning of a threat from Aquasuite. I even turned Kaspersky off. It will not let Aquasuite update to new version. If Kasperksy is the problem, why did it allow Aquasuite for the first initial install and second update to X.57 with no problems? Kaspersky also says Aquasuite is missing digital signature.
This post has been edited 1 times, last edit by "WaterBoy61" (Sep 27th 2022, 1:36pm)
Tuesday, September 27th 2022, 1:55pm
The problem is your kaspersky, add an exception for aquasuite and ALL dll files. This is a false positive.
Do not use this useless software.
GMdoghunter
Tuesday, September 27th 2022, 11:35pm
Totally agree with Sebastian here rid yourself if you can of Kaspersky software.
WaterBoy61
Wednesday, September 28th 2022, 9:24pm
I am on version X.59 now. I contacted Kaspersky support, and it turned out to be a false positive.
