• 18.11.2026, 15:00
Caldorian
Aquasuite Audio Filters not working after system reload
Friday, November 11th 2022, 11:43pm
Previously, I had my system setup with some RGB profiles that had the lighting react to the default Low/Mid/High audio filters in Aquasuite so the lighting reacted to system audio. I had to perform a fresh OS install, so I backed up my Aquasuite settings, performed the OS install, and then re-installed aquasuite and restored the settings from the backup files.
All my other settings all restored; my custom dashboard pages became visible, the profiles I had setup for all my devices were available, and the lighting profiles I had responded to the automatic profile switcher I setup. However, the one profile I had setup for dynamic audio based lighting no long works, with the lights maintaining only their background color.
Aquasuite sees the system audio; if I select any of the Volume options my lights start responding. Its just the selection of the frequency based filters that isn't working.
Anyone got any suggestions? :?:
don_dolarson
Tuesday, November 15th 2022, 9:54pm
I've had problem with exactly the same thing back in time. In my case it was caused by Nahimic service/process bundled with audio drivers caused by Aquasuite update as it worked flawless before. It took me a couple of months to figure it out. Check any service/process responsible for audio processing and stop it temporarily.
Caldorian
Wednesday, November 16th 2022, 5:19pm
Thanks. I forgot I also swapped the motherboard, in the system and that caused the audio driver to change. Stopping the Nahimic service allowed aqua suite to start responding to the frequency levels.
